Low Power Home Server Spec Needed
23 Jun 2007
South East
As title really.
I need something reliable, doesnt have to be a power house but I'd like quick access to media and downloads and plenty of space for backups.
The biggest factor is low power consumption.
As for budget. Id like to say 400 at the very max but I'd hope I dont have to go anywhere near that..?
(Budget doesnt include OS btw)
Thanks for any suggestions! :)
Do a google for Tranquil BBS2 (barebones2)
it sounds like it would meet your requirements and is what I use and find it fantastic
It looks good but it seems a lot of money, considering I'd need to buy the drives on top. Having had a look at WHS requirements I could do make with an old skt939 build.
Shame I've got nothing laying around..
Have a look at getting a dual core Atom motherboard combined with a PCI SATA controller card. Will be very low power and support lots of storage.
Here's a basic spec. Add a case/PSU of your choice and have a look on some popular auction sites for PCI SATA controllers with 4 ports. Gives you 3TB of storage and in a very low power setup for £400.
Presuming you only use the 5 bays in the backplane then it gives you an extra 3 HD spots to fill. Personally I would put one main HD on the internal rack which you install the OS on and keep the backplane for expansion. I would also recommend permanently keeping one slot on the backplane empty for each upgrade (add new hard disk into empty slot and then remove the smallest capacity drive and sell).
Icy Box IB-555SSK 5-Bay SATA/SAS Hard Drive Backplane £96.99
(£84.34) £96.99
(£84.34)
Samsung EcoGreen F2 1.5TB SATA-II 32MB Cache - OEM (HD154UI) £72.99
(£63.47) £145.98
(£126.94)
Gigabyte GA-GC330UD Intel Atom 330 Mini-ITX DDR2 Motherboard £65.99
(£57.38) £65.99
(£57.38)
Crucial Value 2GB (1x2GB) DDR2 PC2-6400C6 Single Module (CT25664AA800) £27.99
(£24.34) £27.99
(£24.34)
Sub Total : £293.00
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 15% VAT : £45.45
Total : £348.45
