Low Power HTPC / NAS Challenge
18 Oct 2002
Bristol
I want to build a HTPC which shall be also used as a NAS and on 24/7.
Requirements:
<50W idle power consumption
Powerful enough for Bluray playback to 720p screen
1TB+ local storage
Quiet
Desktop/HTPC case
So far I'm thinking about these components:
Core 2 Duo E7200
ATI Radeon HD 4350 with passive cooling
Hitachi Deskstar 7K1000.B 1TB SATA-II 16MB Cache
Antec NSK 2480 Desktop Case - Black/Silver
Antec EarthWatts 380W PSU (quiet enough?)
2x2GB PC6400
Pioneer BDC-S02BK Serial ATA Dual Layer ReWriter
Question over the motherboard, which Intel chipset has the lowest power consumption?
Asus P5QL Pro Intel P43?
I doubt there's much chance of that being under 50w.
My HTPC idles at around 70-75w and is this spec:
- AMD 5050e X2 energy efficient (45w cpu)
- Gigabyte MA78GM matx mobo
- 2gb RAM
- 2x HDDs
- TV Card
- MAudio soundcard
If you want low power, you would be wise to look at CPUs that are less than the 7200's 65w.
The E7200 uses WAY less than 65W. See this system Tomshardware built with the E7200:
http://www.tomshardware.com/reviews/intel-e7200-g31,2039.html
Idle:
Peak:
50w at IDLE is quite a lot.
Yeah - that's the upper limit, 40W would be better!
Cool, that intel cpu does well! :)
I have remeasured my AMD setup and it's idle energy consumption is roughly 60w. My old HTPC was 145w, so quite a difference, and with turning it off at the plug, i am now saving £50/year in electricity alone...
