- 12 Nov 2011
Hi All,
I'm new on here, I've been reading a lot of forum posts all over the place and Im getting so confused I decided to join and ask the experts on here for help
I've seen a few of the newbie htpc threads but non of them seem very conclusive or seem to miss out a few things I want. I'm a newbie to htpc's as well.
I want to build a low powered cheap htpc if possible
to do the following
Case 1
run all media including 3d with xbmc. I have a nas box so it will primarily be just streaming from that or browsing flash based sites like iplayer hd etc.
it also has to be as quiet as possible. Some threads talk about the AMD llano processors but say that they cant do certain tasks? Some threads also say that XBMC hardware support on AMD processors is patchy?
additionally it should support from 5.1 sound upwards.
Case 2
if case 1 isnt possible, something that with the same specs that will run with Windows (im not a big windows fan so would like to avoid it if I can). What version of windows would I need as well?
For both cases a media remote and keyboard if needed that will work out of the box.
Thanks for reading
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
Case 1
Case 2
Thanks for reading
