Low profile card for SFF PC
4 Dec 2002
Bourne, Lincs
I’m after a single slot low profile graphics card for light gaming duties and YouTube/browsing will go into a Dell SSF machine so ideally needs no external power connector
Any suggestions
Thanks
I think your only current option is a GT 1030. Gaming duties would need to be very light and you need to pick carefully to make sure you get GDDR5 rather than DDR4. You could try a wanted ad here.....
when you option is a 1030 sounds like it would be easier to get a cpu with igp and just use that, especially if its very light gaming :)
MSI have just announced a 1630 without any external power connector.
The ITX variant is single slot but not low profile though?
Despite the lack of a decent media block, those single slot low profile 6400 are probably the OP's best bet.
There are some TU117 (1630, 1650, etc.) based cards like the T600 but they have been cut down a lot.
T1000 has a similar spec to 1650 but is around twice the price of the 6400.
Not low profile.
Good Point. Well made.
Although just seen MQX (never heard of em must be OEM) GTX 750's 4gb low profile single slot says 14 available but cant list it as its one of those sites you cant mention. Gigabyte used to make GTX 750ti's single slot low profile I had one of those in a Lenovo SFF for games.
I currently have a KFA2 low profile 750Ti OC slim in my optiplex 330. The card is single slot but the cooler extends beyond a single slot width. Nice card though and it does what I need it to do.
