Low Profile Coolers.
18 Oct 2002
Swindon
I have an old Coolermaster ATCS 110 case, that i want to to throw in a nice new i5 / i7 setup, however I am limited to the CPU cooler space, As I cant really have anything with a 120mm fan as they obstruct the case from fitting properly. I currently have a 120 True Black on my Q9550 that is a pain to close up.
What CPU coolers other that the stock one, or the Sythe Shuriken are there.
Cheers
Dusty.
How about the Noctua NH-U9, looks beefy and compact.
The other options are low profile coolers such as the scythe shuriken.
I have fitted some 120mm to my old build (old HP PC) that had a compatibility with 80mm rear fans too. You will need to cut some bits off & drill new holes etc. 30 min job.
I suggest either getting new case or getting a watercooling set and fit it to your case :p
There are a lot of nice cases @ overclockers (Fractal Design Define R3)
Just my opinion.
