I'm wondering if there are low profile CPU blocks out there. In particular I'm hoping for ones where the barbs come out sideways, as these should be slimmer than a normal block with 90 degree barbs. I found an old GPU one:
I'm trying to work out if a watercooled motherboard can fit into a 1U box (max 44mm high) - the limiting factor seems to be the waterblock.
Thank you
edit: I've found a slightly more modern version by EK, though the mounting holes don't line up well with a motherboard, it's better than the dangerden in that respect.
Thank you
