Low reasource office apps (.pdf and .doc)
1 Sep 2005
Hi,
Right at my place of work we have to open a lot of .pdf and .doc files. I don't really need to edit them just look at them. The problem is we don't have great computers and they struggle with this. We have full blown versions of ofiice 2003 and Acrobat reader 8 installed.
So the question is this. I know there are 3rd party versions of this SW out there, for at least just reading the documents. The question is reasources, what it the best program to use to view these file types in terms of the system reasources used?
Cheers
-Howard
FoxIT Reader for .pdfs.
Freeware.
There is a freeware microsoft document reader too from Microsoft themselves. Just for read-only....google it.
just buy new pc's
the ammount of time saved by using a half decent pc outweighs finding other solutions..
just buy new pc's
Even so Foxit Reader is definitely worth a look, completely replaced Adobe Reader for me at home. Will get round to installing it at work sooner or later.
just buy new pc's
This honestly.
I can't imagine how ancient and slow the PC most be if it can't user Microsoft word with out slow down, even an ancient system we had at work (an old P4 with 256MB of ram) ran with no problems!
Cheers just opened a pdf with that and its much quicker. I will try the free office readers when I get 5.
just buy new pc's
Big company - no joy. Been trying to get that point acrodd for the 8 months I've been here. The sad thing is we make computers!
Well its all a question of reasources, the way we work requires outlook open all the time. It also requires 3 instances of IE. and 2 other applications. Thats not counting the apps that are installed and running in the task bar. Add to that a browser to check our essensial documenmts and your using a lot of system resources.
Then if there is a bulitin of note its normally in a word document or pdf so you have to open another application to read that!
I have a 2GHz with 512MB of RAM and it struggles. My job it measured by the length of time on a call so ever second counts too!
Cheers
-Howard
I've seen quite a few sites/apps that don't work with firefox/IE7 now, wonder what the real difference is.
you mean IE tabs? I think I tried that and it did not work.
From what I've been told a lot of web programmers are lazy and use bugs within IE 6 to format the page correctly and they are not certified to the international standard (WWW3????).
IE Tab extension should definitely do it, it is simply rendering internet explorer browser object into Firefox, there is no reason why it shouldn't work if you ask me.
I have tried several applications that need IE in it and its worked flawlessly.
