There are various threads on here with people who have very high overclocks and insanely low temperatures.
There are people on here running CPU's that are clocked heavily yet still have temps lower than my Q6600 at stock.
Now look at my PC spec in my sig and my idle temps are currently 38, 38, 32, 32.
Under load, Prime95 I am hitting 47'c. My case is tidy, cables are tucked away, nothing internally to restrict the airflow. My CPU fan is blowing up through the HSK into the built in 120mm fan drawing air out.
The room my PC is in is very cool, the PC is under the window, the radiator is off and the floors are wooden.
So how do you do it !?!?!
then you will understand
