Low wattage Socket 775 CPU advise please
5 Mar 2003
Swadlincote
After a low wattage socket 775 cpu and wondered which are the best to go for. Needs to be budget pricing.
Cheers! :)
Any 45nm Core 2 Duo chip should do the trick, they undervolt nicely if your motherboard supports low adjustable vCore! :)
That's a nice job on that e8400! Got mine @ 1.26v 3.6ghz. I'm rubbish at working this out, but anyone got a ball park estimate of the cost of power saving if able to get it down to 0.96?
You just need to buy yourself one of these power meter jobbies and check the readings yourself (before/after undervolt) and then just do the maths based on what you pay per kWh.
a e5200 sounds like the chip for you, under-volt well(if your motherboard supports IT) and if you ever need the extra power you can clock it to 3.5ghz easily.
this looks like 65w though after investigation. Ive just found a celeron 430 440 is only 35w. Surely this is a better alternative?
An E5200 won't use much Wattage when Undervolted, and still be a very capable processor!
The question is will you be using a motherboard with adjustable vCore that can be lowered?
i have one of those. picked mine up on the MM a few months back when i was desperate for any old s775 cpu to get my pc up and running again. as i don't game anymore, it's absolutely perfect for normal windows usage. it wasn't until it turned up i realised it could run 64 bit windows and is basically a single core e2160. so it clocks like a trooper too.
this sounds like just the job!
