- 18 Jul 2006
I decided to have a go at overclocking my Pentium D 950. I've done some reading up on it but decided to try and use the Asus Ai Booster program that came with my Asus mobo instead of using the bios. Just seemed easier to use as I'm a beginner. I managed to overclock it 15% (500mhz), any higher and it became unstable.
The thing thats puzzling me though is I was expecting an increase in the temps but they actually got lower
Both my idle and loaded temps are less than when the cpu was running slower. I've had a search on google but can't seem to find an answer......can anyone tell me why this happening?
Cheers
Here are a few pics:
Idle - not overclocked
Idle - overclocked
Loaded - not overclocked
Loaded - overclocked
Both my idle and loaded temps are less than when the cpu was running slower. I've had a search on google but can't seem to find an answer......can anyone tell me why this happening?Cheers
Idle - overclocked
