I had a mild OC of my 2500k of 4.3Ghz, and I thought i'd take the plunge and crank up the vcore a bit and reach 4.5.
My coretemp/hwmonitor temps at 4.3 were mid 60s, maxing at 70-71 degrees and now i'm getting 60-67 across all cores, nothing higher than that. CPUz is showing 1.296-1.3v under prime95 full load, bios is showing 1.32 under load. It's really confusing me and I'm worried that there's something wrong with the hardware..
It shouldn't be COOLER! D:
This is with a gellid tranquillo rev 2, a front stock fan in that came with the case and a side antec tri-speed 1200rpm job pulling air in.
