So after playing CSGO for a long time on a 750Ti, I decided it was time to upgrade, A. because of FPS drops on some of the newer maps, B. because I'd like to be able to play some new games coming out.
So I installed my 290 today and FPS doesn't seem to have increased all that much.
It seems more stable, and the maps where I used to get low FPS, I now get a far bit higher, but in general, frame rate seems to be around 150-250 whereas before it would be maybe 120-220. Settings don't seem to have a great deal of impact on frame rate at this stage.
For comparison - a friend with the same card but a newer CPU etc. achieves 300-400.
Card is a Saphire Tri-X. I've checked the clock speeds while playing in Windowed mode, and the CPU sits around 997Mhz, memory at 1300Mhz, temp at 60-67c and fan between 35-38RPM.
So it is a simple case of my CPU being a bottleneck?
