Pinkeyes said:Hi
I have an MP3 file with a 320kbps bit rate quality, and would like to drop it to 256kbs or lower so it will play on my car radio.
Can anyone suggest a good free program to do this for me ?
Thanks
Pinkeyes said:I re-read the specs (it's a Blaupunkt Woodstock DAB54) and it claims it plays MP3s from 8 kbps to 320 kbps. So I moved the MP3 off the SD Card, formatted it and moved it back - radio then played it fine at 320 kbps.
Thanks for the links though, if nothing else it means I can use them to fit more music on my cards.
Wouldn't like to try shrinking one to 8 kbps though !
