Lowest CPU wattage?
TDP? sorry lol i'm not sure what you mean :o
I want to build a file server/print server/download box/RDC box all in one that will running 24/7 so cheapest running is a must.
i dont really want VIA/EPIA cpu cos they're slow and expensive.
thanks
TDP iirc is how much power the cpu uses under full load.
If you want dualcore then theres also the 35 watt version of the x2 3800+.
Lower tdp usually mean cooler too.
