**Lowest Price in UK** 50 Pack Datawrite Titanium DVD-R 16-Speed £4.49!
22 Aug 2010
We have a limited time offer on 50 packs of Datawrite Titanium DVD-R 16-Speed for only £4.49. Hurry as this offer is only limited and will increase in price in the next few days.
Datawrite Titanium DVD-R 16-Speed Branded VX2 - 50 Discs (TITANIU027) @ £4.49 inc VAT
Datawrite have been busy producing an updated version of their Titanium disc range, branded 'vx2'. Datawrite Titanium 16x Branded Blank DVD -R have been some of the best selling DVD in the UK and Europe and have proven to be hugely popular with OcUK customers.
The disc appearance hasn't changed much, with the tough titanium sandblast colour effect and classic Datawrite layout - logo at the top of the disc, disc information to the sides and a 4-lined area at the bottom to display the disc contents.
Datawrite Titanium vx2 16x Branded Blank DVD -R in Packs of 50 is a DVD recordable format. A DVD -R typically has a storage capacity of 4.71 GB (or 4.38 GiB). The larger storage capacity of a DVD -R compared to a CD -R is achieved through smaller pit size and smaller track pitch of the groove spiral which guides the laser beam. Consequently, more pits can be written on the same physical sized disc. In order to write smaller pits onto the recording dye layer a red laser beam with a wavelength of 640 nm (for general use recordable DVD, versus a wavelength of 780 nm for CD -R) is used in conjunction with a higher numerical aperture lens. Because of this shorter wavelength, DVD -R use different dyes from CD -R to properly absorb this wavelength.
Specifications :-
- Model Number: TITANIU-01007
- Product Name: DATAWRITE TITANIUM VX2 DVD-R 4.7GB 16x SPINDLE 50PK
- Package Type: Spindle
- Media Type: DVD-R
- Size: 4.7GB - 120min
- Speed: 16x
- Pack of: 50
- Special Features:
- High quality dye
- Improved long term performance
Only £4.49 inc VAT.
ORDER NOW
No, Not Printable.
I would go for:
Traxdata Ritek 8x Full Face Printable G05 DVD-R - 50 Pack Tub - RITE601 @ £7.59 inc VAT
Traxdata Ritek 8x Full Face Printable G05 DVD-R - 50 Pack Tub - With RITEK's Printable CD-R & DVD, you can enjoy and easily personalize your preferred images, text and combination on the disc's surface. The RITEK Inkjet Printable Disc range provides you the “Photo Image” quality output. All you have to do is just simply insert your disc into the “disc printing” feature ready printer and wait for your professional result.
Key Features
Famed G05 dye
Traxdata branded
Pod of 50 Discs
Full face printable right to the hub
Speed: 8x
Technical Specifications
DVD-R
Product Code: RITE601
Capacity (Unformatted): 4.7GB
Video Recording Time: 120 min (Standard)
Recording Speed: 8x
Recording Material: Premium Organic Dye
Recording Wavelength: 650 nm
Diameter: 120 mm
Thickness: 1.2 mm (0.6mm x 2)
Full-Face InkJet Printable
50 Tub
Only £7.59 inc VAT.
ORDER NOW
