** LOWEST PRICE YET: PHILIPS 40" 4K WIDESCREEN LED MONITOR!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
A truly incredible deal for this equally truly amazing monitor from Philips, ENDS WEDNESDAY:
Philips BDM4065UC 40" 4K 60Hz Widescreen LED Monitor - Black @ £529.99 inc VAT
See the big picture with all the details. The expansive 40" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in Ultra HD. Expand your viewing experience with the monitor that is designed for the way you work.
These latest Philips screens deliver UltraClear, 4K UHD (3840x2160) pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets. Philips displays will give you UltraClear images.
Philips VA LED display uses an advanced vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 176/176 degree extra wide viewing angle, resulting in crisp images.
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturati on and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
Mobile High Definition Link (MHL) is a mobile audio/video interface fo r directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
Features:
- Expansive 40-inch class brilliant display
- UltraClear 4K UHD (3840x2160) resolution for precision
- VA display gives awesome images with wide viewing angle
- MultiView enables active dual connect and view at same time
- SmartImage presets for easy optimized image settings
- LED Technology ensures low power and natural colors
- Slim bezel design for a stylish look
- Powerful 7-Watt speakers to unleash your content
- USB 3.0 Hub for convenient access and fast charging
- SmartConnect with DisplayPort, HDMI and VGA connections
- MHL technology for enjoying mobile content on big screen
- VESA mount allows for the perfect setup
Specification:
- Display Screen Size: 40"
- Aspect ratio: 16:9
- Panel Type: VA
- Brightness: 300cd/m2
- Contrast Ratio: 5000:1 (Typ)
- Dynamic Contrast Ratio: 500,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 3ms (GTG)
- Viewing Angle (H / V ): 176 ° / 176 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)
- USB 3.0 Hub: Yes
- Speakers: Yes (2x 7W Stereo)
- VESA: 200x200mm
- Warranty: 2yr (On-Site with Philips)
Was [£599.99] Inc. VAT
Only £529.99 inc VAT.
ORDER NOW
Anyone know if this monitor will work at full resolution with the integrated Intel 4600 graphics processor in my 4770K? I am only using for business apps not gaming.
The graphics chip spec seems to suggest it does support 3840x2160 @ 60Hz with DP1.2 but i have read of problems in a review i found of 4K monitors and this setup - "We were able to get the full resolution and refresh rate with DisplayPort in MST mode, but the display was extremely choppy to the point of un-usability"
Ta
p.s. Hey - my second post in 13 years - is this a record?
- Christmas image on monitor
- posted in September
- Christmas is coming
Gibbo = Santa Claus
Great price for this... I'm really tempted by one but holding out for G-Sync.
Using a 28" 4K day-to-day, it definitely works, but there's no doubt at all that 40" would be a much more comfortable size for the res.
It said ending Wednesday I had this in my basket got back 16:00 had gone up. Oh well I will wait till after xmas now. Pity you didn't state a time that the offer would end.
Yes, it does. Been using one with an i4690K for months and it works AOK at native font [ie 4K] with Win 7.64 Ent. Never tried it with games although old legacy games seemed fine thus far. As you know, the i5 4690K has the same HD4600 graphics as the i7 4790K.
Currently using the Asus Z97 v10.18.14.4206 and is AOK - although 2 of the earlier Intel versions from The Net was iffy.
Do not be taken-in by adverts, be they from self-certified experts or "advertisorial" worshipfuls, about "colours are Amazin'", etc. They are not out of the box. This item is not cheap from the factory for no reason, its price having dropped from God to Commoner's Muck categories over a short time.
At current OCUK price, they are OK though. Bought mine from an Italian selling in UK Brazilian Jungly for slightly more than current OCUK's price. You'll be buying this for screen real estate @4K and perhaps little else.
Apologies to OCUK if this comment seemed manipulative.
Above comment was meant to answer "maxicat"s query [#3] about, "....Anyone know if this monitor will work at full resolution with the integrated Intel 4600 graphics processor in my 4770K? ..."
Thanks for the info dlte353.
I went for one in the end and just got it working full res at 60Hz using the Intel HD4600 graphics processor in the 4770k. It seems fine.
