lo all
Since putting my PC in an Eclipse, I've noticed that my motherboard has issues seating my X1900 in the top 16x slot correctly. I may have had the issue in my previous case, but it was made of steel, so was more solid.
Anyway, I have an Evercool VC-RE mounted on my chipset, which I was recommended as it was apparently the exact same height of the original. I've noticed that the card is touching the Evercool when inserted, which leads me to believe that the card is not 100% inserted.
It does work, but if I knock my PC, such as the knock of the sidepanel being attached, my PC sometimes freezes. Upon rebooting, I'm greeted with the beep code "long beep, short beep short beep". The pc will refuse to POST until I put a small amount of pressure on the power connector end of the card, to reseat it in the slot.
What can I do to work around this problem? Do I need to find myself an even shallower Chipset cooler? Can the lower 16x slot be used without detriment? (I'm aware that this slot can only function at 8x)
Thanks for any help in advance
