LP2475W or U2410 or ?
2 Oct 2003
Chester
Which is the better monitor (or others in similar price range)? Decided to go for IPS and has to be at least 24". Tempted by the HP but need some reassurance :)
Yep. Pretty much the same, but the U2410 has a through mode for gaming and some more features to deal with the wide gamut issue. Other than that - pick whichever you can find for the best price.
They're the same, essentially. The Dell has better firmware. However if you're not bothered about colour accuracy and switching between modes etc., go for the LP2475W.
I had that decision to make....both are equal to be honest if you look at reviews there's basically hardly anything between them so just go for whatever you like the look of maybe?:p
I bought the HP because was a on a budget which didn't quite stretch to the Dell and love it a lot.(any IPS panel is brilliant anyway)
From experience I reckon Dell have better quality control on its product (I had 3 LP2475ws and all were faulty, also had a 2407WFP (rev A04) and it was spot on)), so that I would tend to take the Dell over the HP...
