LR 4 exporting issue
1 Mar 2007
Portsmouth
Anyone having issues, ive started to find that once I export to .jpeg from an original RAW file that the export loses a lot of the sharpening. Ive not really noticed this before until today but thats only probably because iam using LR more and noticing more things.
A quick google serch seems to suggest there has been a problem for awhile. Maybe I need to change my export settings?
Example
Still having issues, upgraded to 4.1 RC2 right one is the exported one...
I can't really tell from those sizes whether sharpening is different or not. You can increase the output sharpening for screen or print when exporting. I usually have my sharpening around 35, masking 60. However, unsharp mask works a treat in DPP or Elements.
Thanks but I leave 'output sharpening' unticked as I do all sharpening in LR itself.
This is really bugging me :mad:
I don't know but maybe Output sharpening tick box on export is tied to the sharpening slider in the development module? Perhaps then people doing a bulk export and don't want any sharpening for any of the photos means it's just a single tick box.
Maybe try ticking the box and then doing 0% sharpening and then 100% and comparing the difference to see if it has an effect?
p.s. LR4 4.1 has now been released, no need for RC2.
