LSD in layman's terms?
11 Jul 2004
Neptune
What is it and what does it do/benefit? Might be a newbie question but I'm going to ask it anyway!
From Wiki:
The main advantage of a limited slip differential is shown by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate freely—the torque transmitted will be equal at both wheels, but will not exceed the threshold of torque needed to move the vehicle, and thus the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use, such as driving in mud, off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the angular velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some traction available on at least one of the wheels."
I'm still none the wiser.
Help.
Best way I can think of it.
No LSD - Wet roundabout, foot down, understeer crash and die
LSD - Wet roundabout, foot down, grip and go
When one wheel starts to spin power is shifted to the other wheel.
With a standard diff, when one wheel spins it just keeps on spinning until it grips.
Indeed, Phate hasn't got a clue. :p
But we knew that anyway
Wet roundabout, inside wheel has decreased traction and power will go to this wheel with an open diff. ergo wheel spin on that wheel.
With a Limited Slip Diff it "limits the slip" to the wheel with decreased traction. hence the name.
There is a whole load more to it than that as you get get 1 way, 1.5 way and 2 way LSD's but that about sums it up
An LSD does not prevent understeer, it's purpose is to improve traction where it would otherwise be limited by one wheel losing grip.
A differential that helps prevent the wheels from spinning or losing traction by diverting torque from the wheel that is slipping, to the other that is not.
The LSD will allow for some difference in wheel speeds, to allow for smooth cornering and general driving - but once the difference in speed between the wheels reaches a certain point (i.e one is spinning on a loose surface, the other is not), it will start to work to reduce the difference in output by transferring the torque between the wheels, maintaining traction.
There are numerous ways an LSD can be designed to do this - some use gears, some use clutches, others use viscous fluid-based mechanisms.
Do that many cars on the road have an LSD?
I have had Integra's and Civic's and I think my Saab has LSD too, all fwd.
I can't think of many other than lots of BMWs.
I have to admit that I forgot that civics have LSDs, I thought that only the 'teg had it, don't ask me why.
Which saabs have an LSD?
Why? An LSD works the same front or rear wheel drive.
You are not putting that much power through most FWD cars to require an LSD, equally with RWD the back end of the car is lighter so an LSD is more beneficial even at lower power levels.
Only the JDM Civics have LSDs (apart from the 1 special edition) and then only Type-R have them standard fit. There are tonnes of cars with LSDs on, pretty much anything JDM and sporty has one in there.
A fair bit of stuff on the road has an LSD - virtually any performance car, many off-roaders, small sports cars like MX5s, turbocharged Nissans, various BMWs, Mercs, a fair few trucks, so on and so forth.
Lots of classic cars have LSDs too, again, virtually anything 'performance' or with a rallying/racing heritage. Some factory fitted, some not (or a factory/aftermarket option).
In RWD applications, an LSD allows me to hold the tail out when I want to - with no LSD you have to rely a lot on momentum and weight transfer to hold the tail out, after a while one wheel will just spin to obilivion and you stop drifting.
That's a very generalised statement.
Less power doesn't mean more grip, especially with FWD.
