- 9 Jan 2010
- Sunny Brizzol
Hi Guys,
I am running an LSI 9260-8i Raid card, well in fact its an IBM M5014 but just re-branded from the LSI 9260, I have it set up and running a Raid-5 array with 4 x 3TB WD RED drives, all working fine but I have crappy write speeds which is down to it not having a BBU (Battery Backup Unit)
Soooo I just purchased a new BBU and after almost a week of faffing about I cant get the thing to work properly!
The LSI software in windows sees the BBU fine, health status is showing as OK but it shows as Degraded and needs attention (see below)
This stops the write policy going to 'Write Back' which is what I need running to get the fast write speeds but its not kicking in as it says the BBU is discharged (see below)
This controller has a learn feature which is one of the very few options I get with the BBU, when you run it it fully charges the battery no problem then it will sit there and fully drain it to see how long it lasts or whatever so it knows its able capacity etc, this all works fine and passes the learn feature but then when it starts charging itself back up it just stops on 40-something percent and then stops (see below)
I have let it do 2 sets of learn cycles and they both work fine but then after it finishes it will just not charge itself up again and sits there saying Degraded(needs Attention) but there is nothing I can click on to give it attention lol, what can I do, I have been thinking maybe the battery is duff?!
Heres the log, says battery charging is complete but it only gets to around 43% and stops charging the damned thing but yet when you start a learn cycle it will charge it to 100% before it drains it etc
Cheers for any help, bit annoyed right now!
