lsmod output - can you diagnose a problem from this?
28 Oct 2002
Can you diagnose a problem from this info - only in Ubuntu Feisty my system sounds have stopped working. All other sounds work fine. I think its maybe a conflict, i recall installing all sorts of stuff to do with sound through synaptic (trying to get a game to work) - they worked OK a while back.
The system sound that plays when you get to the login screen works but not as Ubuntu loads after login - i assume maybe something else gets loaded as it boots which causes a conflict.
In system sound devices everything is on autodetect though if i try all the options in the dropdwon its OSS that is the only one that works when i click test
Nvidia CK804 IEC958 - plays but with no actual sound, whereas with the other options i get error messages if i try to use devices called Nvidia CK804, or ALSA or ESD.
"audiotestsrc wave=sine freq=512 ! audioconvert ! audioresample ! gconfaudiosink: Could not open resource for writing."
Any ideas?
Module Size Used by
binfmt_misc 12680 1
rfcomm 40856 0
l2cap 25728 5 rfcomm
bluetooth 55908 4 rfcomm,l2cap
vmnet 39076 13
vmmon 113420 0
ppdev 10116 0
cpufreq_powersave 2688 0
cpufreq_stats 7360 0
cpufreq_userspace 5408 0
cpufreq_ondemand 9228 0
cpufreq_conservative 8200 0
freq_table 5792 2 cpufreq_stats,cpufreq_ondemand
tc1100_wmi 8068 0
pcc_acpi 13184 0
sony_acpi 6284 0
dev_acpi 12292 0
video 16388 0
battery 10756 0
container 5248 0
sbs 15652 0
button 8720 0
i2c_ec 5888 1 sbs
dock 10268 0
ac 6020 0
asus_acpi 17308 0
backlight 7040 1 asus_acpi
nls_utf8 3072 2
ntfs 107764 2
nls_iso8859_1 5120 1
nls_cp437 6784 1
vfat 14208 1
fat 53916 1 vfat
ext2 66824 1
mbcache 9604 1 ext2
ipv6 268704 14
fuse 46612 1
ivtv 134544 0
cx2341x 12804 1 ivtv
lp 12452 0
nvidia 4713780 22
usbhid 26592 0
snd_bt87x 16292 0
snd_intel8x0 34204 1
snd_ac97_codec 98336 1 snd_intel8x0
ac97_bus 3200 1 snd_ac97_codec
hid 27392 1 usbhid
snd_pcm_oss 44544 0
snd_mixer_oss 17408 1 snd_pcm_oss
snd_pcm 79876 4 snd_bt87x,snd_intel8x0,snd_ac97_codec,snd_pcm_oss
bt878 11960 0
snd_mpu401 9256 0
snd_mpu401_uart 9472 1 snd_mpu401
agpgart 35400 1 nvidia
analog 12832 0
gameport 16520 1 analog
snd_seq_dummy 4740 0
snd_seq_oss 32896 0
snd_seq_midi 9600 0
snd_rawmidi 25472 2 snd_mpu401_uart,snd_seq_midi
snd_seq_midi_event 8448 2 snd_seq_oss,snd_seq_midi
k8temp 6656 0
pcspkr 4224 0
psmouse 38920 0
serio_raw 7940 0
snd_seq 52592 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_timer 23684 2 snd_pcm,snd_seq
snd_seq_device 9100 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
snd 54020 15 snd_bt87x,snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_mpu401,snd_mpu401_uart,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
soundcore 8672 1 snd
parport_pc 36388 1
parport 36936 3 ppdev,lp,parport_pc
tuner 61864 0
tvaudio 24220 0
bttv 173684 1 bt878
video_buf 26116 1 bttv
ir_common 31236 1 bttv
compat_ioctl32 2304 1 bttv
i2c_algo_bit 8712 2 ivtv,bttv
btcx_risc 5896 1 bttv
tveeprom 15888 2 ivtv,bttv
videodev 28160 2 ivtv,bttv
v4l2_common 25216 5 ivtv,cx2341x,tuner,bttv,videodev
v4l1_compat 15236 2 ivtv,videodev
shpchp 34324 0
pci_hotplug 32576 1 shpchp
snd_page_alloc 10888 3 snd_bt87x,snd_intel8x0,snd_pcm
i2c_nforce2 6784 0
i2c_core 22784 9 i2c_ec,ivtv,nvidia,tuner,tvaudio,bttv,i2c_algo_bit,tveeprom,i2c_nforce2
af_packet 23816 2
tsdev 8768 0
evdev 11008 3
reiserfs 247680 1
sg 36252 0
sd_mod 23428 6
ide_cd 32672 0
cdrom 37664 1 ide_cd
ide_disk 17024 2
generic 5124 0 [permanent]
amd74xx 15260 0 [permanent]
ata_generic 9092 0
floppy 59524 0
forcedeth 46728 0
ohci_hcd 22532 0
sata_nv 20868 4
libata 125720 2 ata_generic,sata_nv
scsi_mod 142348 3 sg,sd_mod,libata
ehci_hcd 34188 0
usbcore 134280 4 usbhid,ohci_hcd,ehci_hcd
thermal 14856 0
processor 31048 1 thermal
fan 5636 0
fbcon 42656 0
tileblit 3584 1 fbcon
font 9216 1 fbcon
bitblit 6912 1 fbcon
softcursor 3200 1 bitblit
vesafb 9220 0
capability 5896 0
commoncap 8192 1 capability
thanks
Diss
