The speakers have their own internal DAC and amp which which will both be tuned to their specific task, I would imagine it will sound better and likely a higher quality than the G6 anyway.Thank you all for responses. USB straight to speakers works fine
Yep I'd use the Kef internal controls for sure. That's what I do with the lsx 1.The speakers have their own internal DAC and amp which which will both be tuned to their specific task, I would imagine it will sound better and likely a higher quality than the G6 anyway.![]()
