LTE5388-M804 Portforward Help
Have you tried filling in the fields?
Which port if the web server running on? 80/443?
Do you have a proper external IP address or are you on CGNAT?
Using a Smarty sim
That's the reason. You can setup port forwarding in your router, but it won't actually do anything because mobile networks use CG-NAT. Essentially a whole bunch of customers go out to the internet through the same public IP address, they're NATted through that public IP.
Check on www.whatismyipaddress.com and make a note of the public IP address it reports. Then log into the web management for your router and look for WAN IP (or internet IP). They'll be different.
