Lucid Virtu Universal MVP Software
I'm trying it at the moment using a Z77X-UP4 TH and Gigabyte GeFore GTX 670 and it's extremely buggy for me. I'm not sure of your reasons for using it, but I've tried in the past for gaming and games crash (or even fail to start).
Seems like the current version of MVP was made for older graphics drivers (both integrated + dedicated). The latest version of MVP crashes for me when my computer turns on, so I'm forced to use an older version at the moment. Apparently they're releasing v2.0 of MVP this year, so hopefully that's much more stable..
If you use it "Overdrive" make sure you turn in game Vsync off an use the one in MVP it has better performance.
Been using MVP with 3 z77 series boards an had no problems.(Arock 4-M pro, MSI and current Asus Sabertooth.
Just wondered when you go into settings you can add applications which has mostly games already setup plus a couple for software so can you add other software to Virtu MVP like video encoding software which uses the GPU so it will use both
Ps am i barking up the wrong tree :D
