A coworker wants me to sort them out with a cheap PC. All they do on it is web, email and some word processing, so a bottom-end budget PC would be fine. I'm not going to bother with the usual building and installation for it - I'm just going to get a pre-built system with everything pre-installed, so all I have to do is uninstall the completely useless rubbish such PCs always have pre-installed.
OcUK isn't the right place for that, so I went looking at the website for a company well known for selling cheap (and not at all good) PCs.
Full system for something like £250, with Vista and a monitor...that would do. A64 X2 4200 is far more than enough for them...but only 1GB of memory. With Vista and onboard graphics, that might be a bit on the low side. DDR2 is extremely cheap at the moment, so I decided I may as well spec it with 2GB instead. The difference in price is less than £15, right? The site has drop-down menus for making changes to the basic specs.
Having the machine fitted with 2x1GB of DDR2 instead of 2x512MB of DDR2 costs an extra £60!
So I looked around a bit more...
The basic spec has a DVD drive, described as "16x DVD +/- RW Drive"
For an extra £10, you can have a DVDROM drive fitted as well. It's a recommended upgrade. The blurb states "Upgrade to this drive to watch and burn DVDs on your PC".
Because, of course, a DVD writer can't read DVDs. You need a DVDROM drive for that. Obviously.
EDIT: Oh, and it has a 250W PSU, for who knows what reason.
They have big name/brand refurbished PCs & laptops. Guaranteed to get a good deal & something reputable
