Lumia 920 Flickering Screen
18 May 2010
Hi,
Does anyone else have this problem, I sent it off for repair of which I waited 3 weeks for it to be returned and the issue is still there :(
It seems to occur in bright light and the screen flickers rapidly especially around the edges, tried everything including rebuild, updates, turn off/on brightness settings etc and of course sending it off for repair
The phone is only two months old if that, where do I stand with it?
Thanks
Hi,
Thanks
Seems odd, is it okay in normal indoor kind of light?
Yes its fine but not always, its completely intermittent but its always more noticeable in bright light like in an office for example
Last night in my flat it didn't do it at all so I thought it was fixed but then in work today it started doing it under the bright lights so I was quite annoyed and frustrated!
Reset it multiple times, work sheet says they adjusted the screen and refitted and it tested ok, its fine right now in using it to post this but i unlocked it 15 mins ago and it was flickering, its almost like a vsync flicker but faster is the best way i can describe it
