Basically, whenever my engine is cold or hasn't been driven yet, it idles smoothly, the revs are constant and there's no noticeable problems.
However, when the engine has warmed up (usually to 90C), it idles lumpily, the revs will alternate by around 50RPM, and you can hear the lumpy idle from the outside of the car. Giving it a little gas will erradicate the lumpy idle, but it will return once you off the gas. A normal idling engine should have a constant 'vrooooom' sound, but mine sounds quite lumpy when warm. As I say again, this ONLY happens when the engine has warmed up, never when it's cold, so does anyone have any ideas?
I've already had the throttle body cleaned out and re-adapted, so this isn't the problem. Back when I had a faulty crank sensor replaced, the mechanic told me two faults came up on the computer prior; a crank sensor (which I've already replaced) and a lambda sensor. The mechanic said the lambda sensor fault may have been trigured by the faulty crank sensor, and told me to leave it for the moment.
So I was wondering, whether a faulty lambda sensor may be the cause for my lumpy idle when the engine is warm? And if so, howcomes the engine only has lumpy running symptoms when it is warmed up, and not cold?
