LURK 1.1 patch #1
Caporegime
8 Nov 2008
Hi,
Just checking to make sure I am placing the patch in the right part of the main folder. Do I just put it in the main SOC file, or do I need to put it in the 'Gamedata' (LURK) file?
Cheers. :)
Also, does anyone have any experience of using the shader pack here? Don't know what I did earlier but it all went a bit screwy, so I decided to do a clean reinstall.
http://sites.google.com/site/kingo64ssite/Home/optimised-game-shaders/stalker-shaders-max
Not sure mate, but if you can't get working why not try Stalker Complete mod? makes the game look great.
Complete is no where near as good as L.U.R.K imo, both looks and gameplay wise.
OP:
Open the 1.1 patch and you'll see a Gamedata folder there with the files intact, drag and drop them into your S.T.A.L.K.E.R Gamedata folder and it'll ask you to overwrite them, click Yes and that's it.
