Lvt Vs tiling
30 Nov 2005
Any thoughts on kardean flooring tile look Vs large format tiles.
Are they comparable in quality, wear and tear?
For hallway and kitchen 45sqm ISH.
I guess the problem with tiles is cracking if you drop a pan etc from the kitchen? I've got a lower end karndean in kitchen and it doesn't look as nice as high end amtico or tiles, but it is hard wearing floor.
Price wise its circa 20q a sqm for karndean lower ends but it looks pretty easy to fit compared to tiles.
I was always of the impression that Karndean marked quite easily and that it was easy to ‘dent’ it
Could be wrong - can’t beat real tiles really - alternatively my mother and father in law went for polished limestone - looks gorgeous - don’t ask me about costs though ha!
I’ve got karndean in my hallyway and lounge and can confirm it is fantastic. No noticeable marks after 3 years, holds up to water/ spillages well. I’ve got proper tiles in kitchen which I prefer for kitchen/ bathroom environments however one of my tiles is cracked (I imagine from just putting down a heavy food shopping bag too heavily) and it really annoys me.
Assuming you lay porcelain... And not ceramic on a floor (unless you're an idiot) then you should be able to drop a pan and do no damage.
The reason floor tiles crack from drops is because people don't get correct coverage and create voids. Regardless of either option you'll need a super level floor so best to tackle that first!
Lft is like 2mm deflection tolerance per meter I think.
given the job I had in removing glazed ceramic tiles from my dining/family room (see below quoted post), I'm not sure I'd 100% agree with this (although you're probably right in principle). Those bad boys, which had been down 5 years during our time in the house, I suspect a further 10+ before that, had no signs of damage. Same tiles still run through our kitchen and out to the back door too. Also, the floor wasn't especially even: approx 5mm elevation shift in one area, just packed out with mortar.
And today, taking up the floor tiles
Start of job:
6 hours later:
56 tiles done, another 118 to go. Bit of a nightmare of a job, to be honest. The tiles come up easy enough with the SDS chisel, but getting the cement up off the concrete floor is a right pain. More so in some areas (near the fireplace :mad: ) than others - was getting the friendlier tiles done in about 5 minutes each, the difficults ones were about 15 minutes each.
