- 21 Nov 2006
Quite simply, is there a way to separately turn on/off an onboard M.2 drive?
Application example:
I currently run 2 OS on one mobo using a hard drive power switch. It enables us to run totally separate systems on same overclock, GPU, etc. Basically, I didn’t want my son trashing my pc. (Works perfectly)
I’m considering an upgrade, but can’t see it’ll be possible for one of us (me) to use an m.2 separately to the other install.
I could remove the drive letter on install 2, but would rather it didn’t exist at all.
Appreciate your thoughts as always.
