Depends entirely on the motherboard and the M.2 stick as to what lanes and speeds are available to each slot.
E.g. if you've bought a PCI-E 5.0 nvme drive, then you may find only slot 1 supports those speeds.
B550 boards have 2 x m2 slots , 1 x pcie4 and the other pcie3 so it won't matter which. Usually the top m2 closet to the CPU is pcie4.Mine is older ADATA XPG SX8200 Pro 1TB. Currently in slot 2 in my board but wanting to swap board to B550 and wondered about the slot then
thisB550 boards have 2 x m2 slots , 1 x pcie4 and the other pcie3 so it won't matter which. Usually the top m2 closet to the CPU is pcie4.
Afaik, the main issue with chipset lanes is that they're shared between lots of different stuff and everything has to pass through a small uplink to the CPU, so there is added competition for bandwidth and a small increase in latency that doesn't apply to the CPU lanes. That's assuming that everything else is the same, e.g. the same PCI-E gen and have 4 lanes available.whether this makes a difference to performance though, i'm not sure
agreed.Afaik, the main issue with chipset lanes is that they're shared between lots of different stuff and everything has to pass through a small uplink to the CPU, so there is added competition for bandwidth and a small increase in latency that doesn't apply to the CPU lanes.
I don't even know if it helps anyway, I've seen some tests where the SSD actually runs cooler underneath the graphics cardheat purposes isn't really a consideration for most ssds outside of PCIE5 drives
If it helps. On my mobo in sig, the M2_1 slot is up next to the ram slots (top-right). My M.2 in there is currently at 25ºC. The other M.2 slots are all located underneath the GPU. In M2_2, my M.2 is at 33ºC. So +8ºC hotter at idle being underneath there.I don't even know if it helps anyway, I've seen some tests where the SSD actually runs cooler underneath the graphics card
I tend to use the one furthest from the GFX card.
