24 Feb 2017 at 09:17 #1 Dariusz Dariusz Associate Joined 3 Dec 2012 Posts 14 Hey Does any1 know if we should defragment these drivers? Regards Dariusz
24 Feb 2017 at 09:23 #2 malachi malachi Soldato Joined 27 Jun 2006 Posts 13,162 Location Not here NO!NO!NO and......NO! But seriously never, defrag an SSD. You will end up damaging it. Depending on what version of Windows you are using the defrag option should not be available on the SSD drive.
24 Feb 2017 at 09:24 #3 hornetstinger hornetstinger Soldato Joined 6 Sep 2016 Posts 15,471 Nope. No need. Also the constant writing will reduce the lifespan of the drive.
24 Feb 2017 at 09:42 #4 Dariusz Dariusz Associate OP Joined 3 Dec 2012 Posts 14 Hey Thank you. Does it mean this is incorrect ? > http://www.ghacks.net/2015/01/20/windows-ssds-and-defragmentation-the-definitive-answer/ Or did I read it wrong, sounds to me like MS is defraging them every 28 days? Regards Dariusz
24 Feb 2017 at 09:50 #5 malachi malachi Soldato Joined 27 Jun 2006 Posts 13,162 Location Not here Dariusz said: Hey Thank you. Does it mean this is incorrect ? > http://www.ghacks.net/2015/01/20/windows-ssds-and-defragmentation-the-definitive-answer/ Or did I read it wrong, sounds to me like MS is defraging them every 28 days? Regards Dariusz Click to expand... Defraging and optimization are two different things. An SSD will be optimized by Windows but it will not be defragged.
24 Feb 2017 at 09:52 #6 SC0TTRS SC0TTRS Associate Joined 14 Jan 2014 Posts 1,612 Location The Matrix I would recommend using a Drive Optimiser/Tools specific to the manufacture such a Samsung Magician used for Samsung SSD's (for example).
24 Feb 2017 at 10:03 #7 Dariusz Dariusz Associate OP Joined 3 Dec 2012 Posts 14 Interesting thank you ! I think thats it will deal with drivers accordingly then.
28 Feb 2017 at 11:45 #8 joeyjojo joeyjojo Soldato Joined 2 Dec 2005 Posts 5,513 Location Herts As above, Windows will do everything needed automatically with no need for extra software. For HDDs that means regular defragmentation (because they are spinning media like a CD or record so it's best if related sectors are near each other). For SSDs that means regular TRIM commands ('garbage collection' that tidies up partially used blocks to keep performance high).
