M-ATX case suggestions.
11 Nov 2009
Edinburgh
Looking to build anew next year. Will probably go the z170 route rather than X99 unless prices come down a tad.
But first and foremost I need a case as I have tired of my Parvum for the simple reason it is not simple if you need to change a HDD or some such. To many screws to undo.
Must be windowed preferably with the window on the left hand side, must not be black, must be able to talke most of my components in my sig. Obviously mobo,ram and cpy will not make the move but the rest will bar the SSD as I have a larger one in waiting.
No particular budget for a case.
Came across this though the window is small and on the right.
https://www.overclockers.co.uk/raijintek-styx-windowed-silver-micro-atx-case-ca-023-rt.html
Any other suggestions welcome.
Cases are a very personal choice, what one person thinks looks great, another person thinks fugly.
You pick a couple you like style wise and check they will take the parts you want to fit.
I am hoping for suggestions to cases I might have missed in my search mate. Not so much what others personally like. As you say I make the final decision but it does help to have suggestions.
I would suggest a case but ocuk website is down.. with any luck there putting the old one backup
I certainly have not come across the first one before, thanks. But the other two seem quite large. Will have proper look tomorrow.
