Budget: up to £700
Uses: Gaming (BF3, Skyrim), Illustrator, AutoCAD, Photoshop, quietness, stability.
What I hope to re-use in the new build:
GFX - Asus Direct CUII HD6950 1gb. I'm worried that this 30cm, 3 slot monstrosity won't fit in most M-ATX cases.
RAM - 8GB Corsair DDR3
PSU - Corsair HX650
I guess the most pressing question is: what M-ATX cases can handle full length GFX cards?
It's been a while since I've built a machine, so I'm not sure about the differences between Sandy and Ivy bridge as far as price-performance goes.
Edit: The reason I want an M-ATX system is that I'm pressed for space at the moment and it'd be ideal if it could fit on top of a 40x40cm filing cabinet.
PSU - Corsair HX650
