** M-Audio is BACK!! ** - New range of studio grade speaker systems at OcUK!
20 Jul 2009
The bleak North East arm pit of Britain
Hello
OcUK Have got a new Studio speaker range with parts landing in to stock as we speak!! Check out the M-Audio below and the new section HERE!!
:D
M-Audio Studiophile AV30 (MK II) Speakers @ £76.99 inc VAT
The Studiophile AV 30 compact powered speakers make it easy to enjoy full, rich sound even when space is limited. They're designed with the same critically acclaimed technology that has made M-Audio monitors popular in recording studios around the world.
- 3" composite woofers > punchy lows
- 3/4" ferrofluid-cooled silk dome tweeters > clear, crisp highs
- OptImage III tweeter wave guides > exceptional stereo imaging
- 15-watt-per-channel amplifier > top-quality components
- RCA inputs
- 1/8"headphone output
- 1/8"stereo auxiliary input
- Front-panel controls for volume and on/off
- Bass boost control
- Dense wood cabinet with bass reflex port design
Only £76.99 inc VAT.
ORDER NOW
M-Audio Studiophile AV40 (MK II) Speakers @ £98.99 inc VAT
The compact Studiophile AV 40 powered speakers deliver the same proven M-Audio technology favored by top producers, recording engineers and musicians around the world.
- 4" polypropylene-coated woofers > tight, accurate bass
- 3/4" ferrofluid-cooled silk dome tweeters > clear, smooth highs
- Optimage iii tweeter wave guides > precision imaging for balanced stereo field
- 20-watt-per-channel amplifier with class a/b
- Type: two-way desktop reference monitor
- Low-frequency driver: 4" diameter, magnetically shielded and curved cone with high-temperature voice coil
- High-frequency driver: 1" diameter, magnetically shielded silk dome tweeter
- Frequency response: 85hz
NOW IN STOCK!!
Only £98.99 inc VAT.
ORDER NOW
M-Audio BX5 D2 Active Studio Monitors @ £191.99 inc VAT
The M-Audio STUDIOPHILE BX5 D2 Active studio monitor speakers. Incredible sounding yet affordable, two-way magnetically shielded studio reference monitors.
The M-Audio STUDIOPHILE BX5 D2 Bi-Amplified Studio Reference Monitors, update the highly popular M-Audio BX5 monitors with new waveguides and enhanced driver integration for extended low frequency response and refined sound. 5 inch Kevlar low-frequency drivers plus 1 inch waveguide-loaded high-frequency drivers deliver exceptional fidelity. The monitors have a bi-amped design with 70 watts of distributed power, tuned crossovers and custom cabinets. The M-Audio Studiophile BX5a Deluxe monitors are magnetically shielded so that all of your electronic equipment can coexist on your desktop without interference. Integral cabinet and electronic engineering work together to deliver excellent bass response. The M-Audio Studiophile BX5 D2 Active monitors have a distinct advantage over unpowered monitors, in that the built-in power amps are designed specifically to work with the drivers and crossovers in a tuned system. Bi-amplification further refines the concept by dedicating separate power amps to the highs and lows. Combined with a finely tuned crossover, this design insures that both the high, and low frequency drivers are asked to deliver only the frequencies they are more efficient at reproducing.
- Incredible sounding yet affordable, two-way magnetically shielded studio reference monitors
- 70 watts of distributed power (30w HF amp, 40w LF amp)
- 5 inch low-frequency drivers with curved Kevlar cones, high-temperature voice coils and damped rubber surround
- 1 inch Silk-dome, waveguide-loaded, high-frequency drivers
- Magnetically shielded
- XLR balanced and 1/4 inch jack balanced/unbalanced inputs
- Power indicator
- Volume control
- Frequency response: 56Hz-22kHz
- Low-frequency amplifier power: 40 watts
- High-frequency amplifier power: 30 watts
- Crossover frequency: 3 kHz
- Signal-to-noise ratio: >100dB (typical, A-weighted)
- Input impedance: 20k ohms balanced, 10K Ohms unbalanced
- Input sensitivity: 85mV pink noise input produces 90dBA output SPL at one meter with volume control at maximum
- Power: factory programmed for either 115V ~50/60Hz, 230V~50/60Hz or 100V~50/60Hz;
- Protection: RF interference, output current limiting, over temperature, turn-on/off transient, subsonic filter, external mains fuse
- Cabinet: vinyl laminated MDF
- Size: 250 mm (H) x 176 mm (W) x 200 mm (D)
- Weight: 5.0 kg/unit
Only £191.99 inc VAT.
ORDER NOW
M-Audio BX8 D2 Active Studio Monitors @ £284.99 inc VAT
The M-Audio® BX studio monitor series is trusted by more musicians and recording professionals than any other. Now, the BX8 D2 monitors extend this legacy with an elegant new design inside and out. M-Audio have leveraged technology from their high-end monitors to extend the frequency response and provide an even more natural listening experience. Custom Class A/B analog amplifiers deliver superior dynamics and tonal accuracy across the frequency spectrum while the latest-generation woven Kevlar low-frequency drivers and waveguide-loaded silk dome tweeters provide rich, defined sound. With the BX8 D2, you’ll enjoy the utmost accuracy in an engaging listening experience.
M-Audio BX8 D2 Features
- Bi-amplified design with 130 watts of distributed power for cohesive, accurate sound
- 8 inch low-frequency drivers with Kevlar cones for rich, defined lows
- 1-1/4 inch high-frequency drivers with natural silk domes and integrated waveguides for smooth, clear highs
- Optimized rear ports for extended low-frequency response
- Magnetic shielding eliminates interference with other electronic equipment
- XLR balanced and 1/4 inch balanced/unbalanced inputs for connecting mixers, amplifiers, instruments, DJ gear, and more
- Volume control
- Includes two isolation pads
Accurate and enjoyable
Whether you’re recording, mixing or mastering, your monitors are your primary reference source. Accurate monitors let you hear exactly what’s happening in your mixes and give you the assurance that your music will translate well to other listening environments. The M-Audio BX8 D2 monitors leverage a decade of monitor engineering expertise to deliver exceptional transparency and sonic definition—allowing you to enjoy marathon mixing sessions with minimal listening fatigue.
Designed for pros—and beginners
Countless pros use M-Audio studio monitors to produce and mix the music and audio you hear every day. The BX8 D2’s make that same design philosophy and technology available to anyone with a passion for great sound. BX8 D2 helps you understand what’s in your mix so you can make better decisions about how it will translate across a wide variety of systems, from MP3 earbuds to car stereos to audiophile rigs.
The high-frequency domes are made from natural silk to counter the audible ringing that is inherent in the poorly crafted metallic materials often found in other monitors. The high-frequency driver is fully isolated from the rest of the enclosure to ensure minimum distortion, providing ultra-smooth frequency response up to 22 kHz. It also features a built-in waveguide, which offers an expansive sound stage and exceptional imaging.
To insure a lifetime of service, the BX8 D2 monitor’s 8 inch low-frequency driver is constructed from woven Kevlar. Kevlar’s high mechanical and thermal resilience makes it ideal for use in speaker cones. M-Audio's engineers also created a curved conical design that improves room dispersion. High-damping reliable rubber surrounds provide percussive musical bass and insure that the cone reaches its optimal excursion for accurate reproduction. The high-temperature voice coils reduce power compression, guaranteeing that your monitors will deliver full performance hour after hour.
Rear-ported cabinet design
The BX8 D2 cabinet is integrally designed with its other components for optimal performance, right down to rounded corners for reduced edge diffraction and superior imaging. The custom rear port is designed to minimise air turbulence and resulting distortion while adding additional low frequency extension.
Bi-amplified efficiency
The Class A/B bi-amplified design dedicates separate power amps to the high and low frequencies—providing ample headroom for even the loudest and most dynamic of mixes. Combined with a finely tuned crossover, the design ensures that each driver only delivers the frequencies that it can reproduce most efficiently, resulting in tonal accuracy and cohesive sound across the entire frequency spectrum.
Find the sweet spot quickly and easily
When monitoring, it’s important to sit in the middle position or 'sweet spot' between the two speakers where the stereo image is optimised. BX8 D2 features a pinhole power LED that makes finding the sweet spot easy. You’ll know you’re in the right listening position when the BX8 D2 LEDs appear to be brightest.
M-Audio BX8 D2 Specifications
- Frequency response: 38Hz – 22 kHz
- Crossover frequency: 2.2 kHz
- Low-frequency amplifier power: 70 watts
- High-frequency amplifier power: 60 watts
- Amplifier power combined: 130 watts
- Maximum signal-to-noise (dynamic range): > 100 dB (typical A-weighted)
- Cabinet: Vinyl-laminated MDF
- Size: 30.48 x 25.4 x 38.1 cm / 12 x 10 x 15 inch
- Weight: 11.97 Kg / 26.4 lbs each
Only £284.99 inc VAT.
ORDER NOW
M-Audio SBX10 Powered Studio Subwoofer @ £368.99 inc VAT
The M-Audio SBX10 Powered Studio Subwoofer is designed to give your monitoring system some serious low end.
The M Audio SBX10 delivers tight, clean bass response down to 20Hz—revealing the extreme low frequencies in your music so you can make accurate mixing decisions. Comprising a 10” fiberglass/paper composite driver, a 240-watt all-discrete internal amplifier, and a variable 50-200Hz crossover, the SBX10 subwoofer delivers unbeatable performance in a compact chassis—great for studios where space is tight.
An oversized magnet, high-temperature voice coil, high-density cabinet and a full complement of inputs are just some of the additional components that round out this high-quality design. The unit even includes a bypass footswitch so you can easily judge how mixes will sound with and without a dedicated subwoofer. The SBX10 represents the perfect addition to any studio monitor setup.
Designed for use with the M-Audio CX and BX Deluxe series—or most other studio monitors—the SBX10 active subwoofer delivers the kind of bass response necessary for music, film and multimedia projects.
The SBX10 subwoofer accepts the two-channel stereo outputs from your mixer, audio interface or sound card, and your main monitors connect to the subwoofer’s outputs. The internal crossover network of the SBX10 splits the signal at a user-defined crossover frequency (50-200Hz), routing everything below it to the internal sub and everything above it to the main speakers. This significantly improves fidelity because the components aren’t tripping over each other to reproduce the same frequency—and each only has to deliver frequencies to which it is ideally suited.
The M-Audio SBX10 Powered Studio Subwoofer Main Features Include:
- 10” fiberglass/paper composite cone driver with oversized magnet and High-temperature 2” long-throw voice coil
- 240-watt Class A/B amplifier with all-discrete transistor design
- Flared rear bass-reflex port
- Variable 50-200Hz crossover
- 20-200Hz low frequency response
- Adjustable gain (-30dB to +6dB)
- Balanced/unbalanced XLR, balanced/unbalanced 1/4” TRS and RCA inputs
- Balanced/unbalanced XLR and balanced/unbalanced 1/4” TRS outputs allow easy setup of 2.1 monitoring systems
- Includes subwoofer bypass footswitch
- Phase switch (0°/180°)
- Over-temperature protection
- Vinyl-covered high-density internally braced 3/4” MDF cabinet with 1” front and Back baffles
- Removable grill
- Removable feet
Only £368.99 inc VAT.
ORDER NOW
You should try andf source some yamaha equipment, its the finest in class for a flat response would probably go down well on here with people who know what theyre on about, sure adam can be better but most of the studios ive visited use yamaha hs 50/80m though these are good deals for people starting off in music some great prices
I have a pair of the AV40s (MK1) hooked up to my iMac, which were £130 at the time of purchase and they're fantastic monitors. Don't know what they've changed in the MK2s though. Dubstep, Drum & Bass, Hardcore Punk, doesn't matter what I put through them, the output is fantastic. There's a bass boost switch on the back if you require more of a kick, I've tried it and found that I don't need to turn it on, even when listening to brown note levels of sub bass. All I will say is I could do with a pair of auralex pads or something to isolate the monitors from my desk properly. The AV40s come with a very thin pad that sticks to the bottom of the monitor for isolation, but it's not really substantial enough.
