M-ITX build
J21
J21
29 Apr 2013
hi all looking at building a m-itx build for my front room to hook up to the tv, usage will be for watching films, utube and browsing the web. i made it as cheap as possible, my budget was around £250 hear is what i come up with.
Your basket
Product Name Qty Price Line Total
OCZ Agility 3 120GB 2.5" SATA 6Gb/s Solid State Hard Drive (AGT3-25SAT3-120G.20) OCZ Agility 3 120GB 2.5" SATA 6Gb/s Solid State Hard Drive (AGT3-25SAT3-120G.20) £89.99
(£74.99) £89.99
(£74.99)
Akasa Crypto Vesa Mini-ITX Case with 80W PSU - Black Akasa Crypto Vesa Mini-ITX Case with 80W PSU - Black £59.99
(£49.99) £59.99
(£49.99)
Gigabyte GA-E350N AMD Hudson M1 DDR3 Mini ITX Motherboard Gigabyte GA-E350N AMD Hudson M1 DDR3 Mini ITX Motherboard £47.99
(£39.99) £47.99
(£39.99)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (TW3X4G1333C9A) Corsair XMS3 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (TW3X4G1333C9A) £31.99
(£26.66) £31.99
(£26.66)
Samsung SN-208DB/BEBE Slimline 8x DVD±RW SATA Drive - OEM Samsung SN-208DB/BEBE Slimline 8x DVD±RW SATA Drive - OEM £17.99
(£14.99) £17.99
(£14.99)
Akasa Slimline Optical SATA Cable, 40cm (AK-CB050-40) Akasa Slimline Optical SATA Cable, 40cm (AK-CB050-40) £2.99
(£2.49) £2.99
(£2.49)
Sub Total : £209.11
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £43.72
Total : £262.33
i have built gaming pc's but i have not done one this size so looking for some advice if this build is ok.
dont you need a processor?
your list seems to be this to me
SSD
Case
Mobo
Memory
OpticalDrive
Cable
CPU and GPU integrated into the motherboard.
Spec seems fine - not sure why you need the SATA cable, I would assume the motherboard would come with 2?
