Hi Guys
I've currently got a fairly standard looking case for my atom based server.
However we've just had some shelves built and foolishly i didnt check to see if the builder was going to make them deep enough ( he's made them so they look "best" in the alcove)
As such the shelf is 30cm deep (my case is also 30cm deep, however this isnt small enough once power cables etc are fitted)
Could anyone recommend any cases which are around 25cm deep at most?
Also my current case only has space for 1 hard drive which i'd like to expand if possible at a later date. Does anyone know of any cases with space for more that one internal 3.5" HD? I also need to be able to use an internal cd drive.
I recall seeing a Lian Li one recently that may have fit the bill but can't remember the model number
Cheers
Cheers
