- 22 Oct 2002
- The bowels of student hell.
Hi guys,
I've set up my spare PC (pII450, 256mb ram) running m0n0wall as my router. I really like it - lots of features and the GUI is very well made - so much better than any commercial routers I have come across.
The only problem that's really getting to me now is that using m0n0wall as my router seems to have made my internet connection really slow. I ran a little test to confirm, downloading the same file (3dmark06) from a swedish ftp:
My PC ---> DI-624 Router ----> 4mbit cable modem (400+kbytes/s)
My PC ---> DI-624 as a switch ---> m0n0wall ---> 4mbit cable modem (5kbytes/s)
The WAN interface in the m0n0wall box is a 10/100 ISA network card. The LAN interface is a 10/100 PCI card.
I tried faffing with the traffic shaper (using the magic shaper wizard or whatever its called) and it managed to up my download speed from 5k/s to 20k/s. Still, it's pathetic. I just don't understand how it can be going so slow? If I put a bucket load of different downloads going I can get it to top out at about 100k/sec, but it's totally stupid because I easily get over 400k/sec when not using m0n0wall
Does anyone know why this might be happening? Could it be a bottleneck in the system between ISA bus and the PCI bus? m0n0wall report the cpu usage as not really going above 10%, and the memory usage stays constant at 9% so I hardly think it's stressing the system.
Any ideas? I'm getting kind of annoyed now. :'(
thx in advance,
DeathByMonkey
thx in advance,
DeathByMonkey
Though I don't think I'd have been much help. Anywho, glad you tried it and glad you got it working in the end.
