- 11 Aug 2009
- Cambridge
So, time has come to throw some new upgrades at my M17X R4, its current spec:
i7 3610QM, 8gb 1600 (Micron according to CPU-Z), 7970M 2GB, 1080P Panel, 2 HDD's, 240W AC
I wanted to know if I could just drop in a 3920XM (its 55w vs the 45w of the 3610qm). Would I be able to overclock this (wouldn't mind getting the CPU to 4ghz or over).
Second question, if I got the Corsair Vengeance 1866mhz memory, would I be able to run this above 1866mhz? My BIOS has an option for 2000 or 2133 (I forget which).
Perhaps somebody has already tried this already. I have AC5'ed my CPU and GPU and I get around 67 and 68 degrees on the CPU and GPU respectively. That's with auto fan profile. If I use HWInfo to put my fans at 7000rpm constant its more like 58/63. My GPU is also overclocked to 925/1300.
Thanks OCUK <3
Thanks OCUK <3
