M2 drive from PS5, formatting to use back in a PC (problem)
25 Aug 2008
York, UK
Hi,
I am trying to format a M2 hard drive for a mate, it has been in his PS5 but he has sold that and wants to use the 4tb drtive in his PC.
He has already tried to format it himself (Windows 10) and failed.
I have tried to format using CMD (as admin), and get a 'semaphore timeout' message.
Not sure what to do to fix this, any advice please?
Thanks
When I managed to get into the drive, there were x2 partitions.
First partition, managed to format that ok, then it let me delete both and format as a whole.
Sorted, thanks.
Don't format the drive, use the clean command in diskpart, but make sure you choose the correct drive first. With everything on the drive wiped, use Disk Management to create a new partition and do a quick format.
I believe its because the PS5 gives it some odd (To PC) information in the drive table that causes the issue. Like darael says go into diskpart, list disk to determine which drive target you want to format, type sel disk (Disk Number you are trying to format) and return, clean. That should revert the drive to bare non partitioned unit and should now be formattable. Should you have further issues i would suggest going into your bios and looking in the tools menu and see if there is a SSD erase/Secure erase option and run it through that.
Hope that helps.
