M2N32 questions
18 Sep 2007
Norwich
Wasn't sure what section to put this in so feel free to get this moved if appropriate.
Have few questions which I’ve been wondering for a while and finally want an answer as it’s confusing me.
1. Have computer as in sig. (AM2 4200, 1gb (2*512mb) OCZ Plat PC 6400 ram, M2N32 SLi) which as been running at 270*10 on 800 or 667 divider can’t remember which now. Tried to upgrade to 2gb ram, 1 stick was dead so back to 1gb.
Ever since building this whenever I select a 11* multi (or any odd no.) the ram apparently runs at 368.4mhz @ DDR800 in cpu-z, whereas in nvidia ntune reports it running at 800mhz. Even multi’s are fine.
For example below is computer running at 2.75GHz with 250mhz HTT yet ram is at DDR916 (CPU-Z).
But at DDR1000 in ntune.
So which do I believe?
2. Do I need to worry about 1 core of cpu failing prime far earlier than other. Core 0 runs prime till I stop it whereas Core 1 fails within various times from 1-20 at most overclocked speeds.
Also can someone tell me what the NB > SB Frequency actually does? Currently set to 270 but doesn’t seem to make any conceivable difference to any speed. So can I leave this set to Auto? Have options from Auto, 200-400.
Sorry for the essay lol, thanks very much for any help.
Cheers.
All odd cpus multipliers will give a ram speed of less than 400mhz when using the ddr800 setting, it's simple maths. With the on chip memory controller mem at 376mhz will give a higher throughput than most DDR 1066 on an intel platform (8-9k score in Everest).
Unless you are moving lots of data the NB to SB speed has little impact on overall speed.
