M5A78L USB3 mobo
Hi, yes that is the mobo. My case has 2 USB (2.0) at the front of it and it needs to be wired to the mobo. Could not find anything in manual that could tell me where to wire it.
Thats odd, it is in the manual,
Thank you Stulid i saw that in the manual and thought that was it. The only thing is im still alittle confused :(
I have 1 connection that fits in perfectly. but then i have other connections called
Red = VCC1
White = Data-1
Green = Data+1
Black = Ground 1
Black = Shield
so i am unsure where exactly they should be put as the names dont match!
