M7 to M9 Transfer
27 Dec 2011
Darlington
I've just ordered a HTC One M9 to replace my old HTC One M7.
How do I transfer all my data from one device to the other ?
My phone is due to arrive today between 12pm and 6pm.
Any help is much appreciated.
Does the m9 require a smaller sim card the M7 as I can not get mine to fit :confused:
Nano sim (M9) vs micro sim (M7). You can get templates to cut yours down if you want to try it, otherwise head into a store or call your provider and they should send you a new one... they might try to charge you a small amount for it though.
I don't see the point of the shift from micro to nano sims. For such a tiny amount of space saved it's a right pain.
Thanks, I'll give them a call in the morning.
