Mac and Partitions
11 Feb 2007
High Wycombe
I'm thinking of buying a MacBook and was just wondering if I can mimic how I have my partitions setup on my Vista laptop.
On my Vista laptop I've got the system partition and then my filestore partition so when I reinstall Vista I dont have to worry about backing up my data each adn everytime.
If I got a MacBook I would put Windows 7 on it, so would I be able to have 2 system partitions for Mac OSX and W7 and then a third partition for my filestore and be able to access the filestore no problems no matter what OS I was booted into.
Cheers.
I don't think you can do that directly via boot camp, though you might possibly be able to pull it off with some voodoo in the disk assistant.
All Boot Camp is, is just a non-destructive automatic partitioner (with one designed function). Plus drivers on the Windows side of course. It's to disk partitioning what AirPort is to 802.11a/b/g/n. The same thing with a fancy name on it :p
All you need to do is:
Decide how big you want your filestore partition
Boot from the disc that came with your Mac, go into Disk Utility, format the disk with 2 partitions (with the second being your filestore partition)*
Install Mac OS X on the first partition
Go into BootCamp Wizard and it'll ask you to resize your OS X partition, which'll create room for Windows.
Install Windows
Done, 3 partitions :p
Of course if you're just going to install Windows on it anyway I would question why you are buying a Mac in the first place?
*The only filesystem that both operating systems can Read/Write is FAT32. This can cause problems if you have files over 4GB.
Install Windows
Thanks for the headsup.
With regards to the why by a Mac if I'm gonna put Windows on it is because this would be a first time Mac buy for me never having used it and having Windows on it would make the transition a bit easier. Well thats my thoughts anyway.
Macs can read NTFS natively. Read/Write with NTFS-3G for free.
The reason why I didn't go into it is because all non-Microsoft solutions to dealing with NTFS partitions have required reverse-engineering Microsoft's NTFS and then re-writing it in an entirely different way.
Put simply: from both a performance and data-safety point, it's not a good idea to use a non-Microsoft NTFS solution. Unless you absolutely have to.
