- 18 Feb 2007
- London
Hi
Every time I get an update for Bitwarden it never completes fully, it updates fine, its just the app is stuck in the update process, in launchpad it has the install bar and says 143.6mb of 143.6mb, I can't open the app from launched due to this, I can open it everywhere else though.
I don't have many 3rd party apps, so unsure if its Bitwarden bug or not.
The only way I can fix is by deleting the app.
Does anyone have a better workaround?
Update/
It did the same with iMovie app as well, I deleted that app and for some reason it decided it will auto install again. As for BW it seemed to update eventually after I plugged MacBook into power, but then I got duplicate apps, (another issue I get sometimes).
I think I will update to Ventura at the weekend, hopefully it fixes some of these bugs.
Update/
