Steedie said:The boxes under your icons
My Computer -> Control Panel -> System
from there go to the 'Advanced' Tab, and 'Settings' in the 'Performance' section
Then in there make sure that 'Use Drop Shadows for Icon Labels on the Desktop' is checked
Problem solved![]()
electric ant said:Check out the forums at Aqua-soft for everything to do with customizing windows to look like Mac. Some programs I recommend are RK Launcher(as mentioned) and Avedesk.
http://www.aqua-soft.org/board/index.php
