Mac Mini 1920 x 1200
1 Dec 2010
England
Hi,
Does anyone know if the late 2012 mac mini can output a resolution of 1920 x 1200 by using a hdmi to dvi port adapter?
I'm looking to upgrade my current monitor and replace it with two 24 inch Dell 1920 x 1200, one will be connected via the display port and the other using the included hdmi to dvi adapter.
Thanks
the 2011 model could do 1200 max so I would think that the 2012 model would as well considering it uses HD4000 graphics instead of 3000
*This model simultaneously supports 1920x1200 on an HDMI or a DVI display (using the included HDMI-to-DVI adapter) and2560x1600 on a Thunderbolt or Mini DisplayPort display or even a VGA display (with an optional Mini DisplayPort-to-VGA adapter, which is compatible with the Thunderbolt port).
Will the next mac mini have an AMD GPU chip? I'd love one with a decent chip and quad i5 for £499.
Nobody knows. Though since they ditched discrete GPU's with the current range and Haswell will improve graphics performance by 30-300% (depending on what you read) it seems unlikely.
