'ello,
I've upgraded to the latest version of Mac OS X Lion via the app store
it's OK, but it's a bit slow compared to the previous version... i was wondering can you check disk permissions/file structure etc. using the OS install disk i got with my macbook like i used to, to see if there is any way i can speed things up? or will it not work?
sorry for the dumb question.
it's OK, but it's a bit slow compared to the previous version... i was wondering can you check disk permissions/file structure etc. using the OS install disk i got with my macbook like i used to, to see if there is any way i can speed things up? or will it not work?sorry for the dumb question.
