Howdy,
This is for those that own a Mac Pro mainly.
Do any of you have a problem with one of your front fans? It's probably an isolated incident, but my front top fan makes a really annoying rattling noise now and then.
Its starts, and last for a few seconds and does this several times. Then it will stop and I might not hear it again for a few days... then it will do it again.
I've checked everything is tight in there, and nothing falling around, but I think I will have to open her up at somepoint and have a proper look... and even buy a new fan
As I say, this is prob just me, but thought I'd ask to see if anyone else is having this problem... and if they fixed it.
The actual noise is hard to describe, its just a rattle that slowly gets louder, lasts for a bit, then gradully gets lower and then disappears. Then it will return again a few minutes later.
I usually leave my MP running pretty much all the time, I might turn it off one night a week, its left running the rest of the time.
Anyone?
ta
Steve M
Anyone?
ta
Steve M
